Philips radiosat 6010
Username: Alexasr
hello, congratulations for the site ..... a great help to many people in trouble! I need the code for this radio, mounted on a renault clio 1999:
PHILIPS RADIOSAT 6010
PHILIPS 22DC461/62E
7700433074N970
FD 11 99 27 2285140
MODEL NO: 22DC461/62E
PROD NO: FD 1199272285140
THANKS IN ADVANCE
Username: Hay88
PortsmouthUk
Post Number: 3595
Alexasr
code 2036
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Alexasr
ALL OK, it works perfectly .... MANY THANKS FOR THE HELP, was invaluable. A PIECE OF HISTORY is alive again! THANKS AGAIN
