Peugeot 306 HDI 2000 CAR RADIO CODE NEEDED
Username: Jeromehamill
Hi I need help with a code for my car radio, i pulled out the fuse and forgot that i didn't have the code. can anyone help.
the details for the radio are as follows;
model=PU-22 94A©
SERIAL=CL041Y0308889
96 392 195
286-8497-33
Any help would be appreciated
Regards Jerome
Username: Hay88
PortsmouthUk
Post Number: 2388
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
