Need code for car stereo please
Username: Whytelj
hi i cant find my manufacture book so dont have the code for my radio but i took it out and got the details which are
MN-22DC27B/62B
PN-FD0302200200199
RN278F20200199
8200057681TD591
T0591
IF ANYONE CAN HELP ID BE MOST GRATEFUL T
tish
Username: Hay88
PortsmouthUk
Post Number: 1892
Whytelj
D591 = 1428 you must hold at end to store code.
please check > 8200057681TD591 and T0591 <
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Whytelj
Hi I've tried this a few times and it's not working :-( It beeped but my radio didn't come on am I doing something wrong?
Username: Hay88
PortsmouthUk
Post Number: 1906
Whytelj
please check 8200057681TD591 number for me.
The Code number is entered by using the remote steering controls, and not through the buttons on the fascia.
you can sen me a photo of label if you like.
Username: Jamieluca
Hi i also need a codefor my vauxhall stereo, after disconnecting the battery. The numbers on the top are:
gm0d3092404029
497316088
13289932
034451
Dont know what numbers you require so i put them all down!
Thanks alot
Username: Whytelj
hi i cant upload the picture it says its too big!!! just took a picture and these are the details
820057681TD591
TOD591
RN278f20200199
model number 22DC278/62B
product number FD0302200200199
Username: Hay88
PortsmouthUk
Post Number: 1912
Whytelj
T0D591 = 1428 so if still not working
and you have entered like i said by using the remote steering controls, and not through the buttons on the fascia.
take to you local Decoding Service to see if they can help you.
Username: Jamieluca
Can anyone help or shall i take it to vauxhall? wifes driving me mad mithering me to fix it!!
gm0d3092404029
497316088
13289932
034451
Thanks alot
Username: Hay88
PortsmouthUk
Post Number: 1921
Jamieluca
Sorry ...not in my database
Try emailing
restoredclassic@aol.com
Mention this forum
Username: Jamieluca
Thanks anyway hay, ill try the email address.
