Ford 6000cd rds eon code needed please
Username: Unco_pom
hi i have a ford focus 2003 with a 6000cd rds E-O-N with a S/N M02077, P/N YS4F-18C815-AD head unit and the car never came with a manual and when i got it serviced they replaced the battery and now im stuck with no music please help for the code cheer luke
Username: Hay88
Post Number: 1683
Unco_pom
please check your serial S/N M02077 is missing a digit}
Username: Unco_pom
Sorry i just rushed out to the car and back haha the s/n is M020771, i tell you it's one of the most difficult thing to take out if you dont know what it looks like underneath but i eventually did it with a coat hanger
Username: Hay88
Post Number: 1684
Unco_pom
your code 2264
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter.
Username: Unco_pom
thank you works like a charm
