Radio codes
Username: Acco
Harlaxton, Queensland Australia
Can anyone help me i bought a holden Vectra with a Blaupunkt 520 radio without a code No.92057951 BP8391Y3013161.i think it is out of a Holden Astra. Thanks ian.
Username: Hay88
Post Number: 1257
Acco
in Queensland
try code 0796
Username: Achinono
Hi,
I have Renault Scenic Megane 02 reg. I lost its stereo code. Can you please help me
MODEL 22DC258/62P
TON193
RN258F20017491
PRODUCT FD0002080017491
8200152345TN193
Thank you in advance
Username: Hay88
Post Number: 1277
Achinono
Your code 2886
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, }
press and HOLD the [ ] button for up to 10 seconds to store the code
Username: Level5
i have a Honda Odyssey 2000 with nav. the radio s/n is M99C200792. Can
someone please give me a code for this? we are leaving on a trip
tomorrow and i can't find the code. we bought the van used...
Username: Regrooster
Post Number: 4334
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Unfortunately DELCO codes are not obtainable for free (using the Serial Number) from anywhere on the Internet as access is required to the original factory database which is only available to the Main Dealer or one the larger professional Decode Services.
The alternative is for your radio to be taken/posted to a Decode Service or your local Car Radio / Audio Shop who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Fairly1
hi,
battery problem with my with my opel combo van last year and radio does'nt work and heading off to england to work for few months - be great to get it working again. anyone help with a code for my grundig car 200 sn: gm 0200x7134136.
cheers
Username: Hay88
Post Number: 1284
Fairly1
try code 8437
Username: Fairly1
tried it hay88 and it worked first time- thanks a million hay
cheers
fairly1
