f the display now shows the correct Code number then Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on to store
Hello, can somebody please help me? Bought car, second hand, didn't get codes. OPEL VECTRA, 1999 manufactured. I need code for CD CHANGER BLAUPUNKT: S/N: GMCDC2W3114068
hi need code for my cd changer blaunkput, got the car 2 weeks ago didn,t no i needed a code for the changer, help.. GMCDC2V8176728 90462566 TYPE-CDC2(WIG)
Posted on Thursday, April 15, 2010 - 12:47 pm: hi need code for my cd changer blaunkput, got the car 2 weeks ago didn,t no i needed a code for the changer, help.. GMCDC2V8176728 90462566 TYPE-CDC2(WIG) ===============================================
Thanks my friend but I can not type the number 7 on my radio how to do this,THIS IS MY RADIO http://www.fiatforum.com/gallery/data/500/medium/blaupunkt-front.jpg
Nedmans code 3415 for fiat how to enter try fiat code first if not then the standed. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " then " - - - - " Enter CODE in the order it is read - eg: For Example, To Enter Code 1234 Press Preset 1 then 2 then 3 then 4 The Code will Enter Itself Automatically
BASIC INSTRUCTIONS TO ENTER A BLAUPUNKT RADIO CODE Switch the ignition key ON Press and hold AS button * and the ON button at the same time Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed If the display now shows the correct Code number then Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
hi got my code 4 cd changer now , put the code in , ER-CDC comes on the screen , so put the code in again and the same message come,s up , its a blaupunkt type-cdc2 GMCDC2V8176728 90462566
Posted on Wednesday, April 21, 2010 - 11:46 am: hi got my code 4 cd changer now , put the code in , ER-CDC comes on the screen , so put the code in again and the same message come,s up , its a blaupunkt type-cdc2 GMCDC2V8176728 90462566 ==============================================
Post ALL the LETTERS+NUMBERS including the one beginning with 7 - - - - - - - - -
Posted on Saturday, May 08, 2010 - 09:56 am: thank you, it's work.
But now ask me CODE for radio player. Fiat Stilo visteon part no. 2FCF-18C838-AE serial no. M013023 model OA fiat part no. 735296994 -------------------------------------------------------------------------------- ----
Try code 3096
Please note : NO MULTIPLE CODE REQUESTS on this forum.
Single free code for personal use only.
This is to prevent abuse of this free service by car radio thieves, traders and other chancers
Posted on Sunday, May 23, 2010 - 09:32 am: hello I need code for Blaupunkt CD changer for FiAT STILO bp15014279065 815 idc a09 7 607 769 150 021538 tanks.. ==========================================
Duplicate request!
Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
Hi Got car with Blaupunkt 6 CD Changer Philips CCR-600 After I enter Code for CCR I still get "beep" at CD playback every 3 seconds. Do I have to enter some additional code for changer? S/N of changer: 09148318
Posted on Sunday, May 23, 2010 - 01:42 pm: Hi Got car with Blaupunkt 6 CD Changer Philips CCR-600 After I enter Code for CCR I still get "beep" at CD playback every 3 seconds. Do I have to enter some additional code for changer? S/N of changer: 09148318 ====================================================
Post ALL the letters+numbers found on any labels, barcodes or stamped in the metal casing of the changer
