Where to put my Subs
I have a Set of Sound Stream 12' subs in a Dual box which is in my trunk. I also have a Single box with a JBL 12 in it but i have no where to put it. I am running two amps so there is no conflict with subs just the delema of where to put the extra. Where in the interior of the car could i put it to make it hit hard?
what kind of car are you using?
1998 Ford Escort SE, very small car
Kraig Gavin
buy a new car
Andrew
haha
the middle of the back seat.. on the seat, or on the floor.
Dont Try This At Home
Just bust out the back glass and strap it on the trunk facing forward.
~oualla!
hiphopanonymous
You should put it at the rear deck man. just replace your factory speakers in the back and mount some subs onto your dashboard.
