Box info?
Username: Ja205
Post Number: 28
building a ported box is it better to make it a little bit larger on the cubic feet or less
Username: Glasswolf
Columbia, SC USA
Post Number: 13089
bigger or smaller than what?
what size subs are we talking about? what's your goal? SPL? SQ?
how much power are you applying to the subs?
Generally, for a 12" sub for example, you can go between 2-2.5cu ft per sub, and tune the ports accordingly. For SQ, aim for 28Hz.
larger for SPL, smaller for tighter detail and punchier response for SQ. Larger will also help a little with mechanical power handling capacity
Username: Ja205
Post Number: 29
im going to be using a rd 1750.1 at a 2ohm load for my re audio sx 10's
im not to sure if i want spl or sq im a daily driver
