Monster 1/0 cheap on ebay...is it any good??
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3019
Found monster 1/0 on ebay for what seems like a good price if it is good wire. thought I would share. anyone know if it is good wire?
40 ft spool is $89.95 shipped = $2.25 per foot shipped
http://cgi.ebay.com/MONSTER-CABLE-40-FEET-1-0-GAUGE-CAR-AMP-POWER-WIRE_W0QQitemZ 300406890474QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f1a55fea#ht_3506wt_ 996
Illinois Braaap MX
Post Number: 3020
Also found this tsunami 1/0 100ft roll for $179.99 shipped..but the pics looks like theres a lot of rubber.
http://www.audiosavings.com/products/Car-Audio-Installation-Accessories/TSUNAMI- 100-FT-SPOOL-1-0-GAUGE-AMP-POWER-GROUND-WIRE/GN901-100.aspx
Diamond Member
Www.stainles... .ecrater.com
Post Number: 22660
That jacket is EXTREMELY thick. Looks even worse than Raptor did.
Username: Poprocks
Post Number: 354
^^^^^It says 4214 strands, but the jacket does look thick.
Username: Th3pwn3r
I compensate...
Post Number: 9598
^Strand GIRTH is important as well :D
Username: Nd4spd18
Philadelphia, PA
Post Number: 11052
With the monster cable, look at the pics, the spool says 1 gauge not 0 gauge
Diamond Member
Post Number: 22662
Strand count is important but such a thick jacket makes me assume less flexibility.
Illinois Braaap MX
Post Number: 3021
Anyone know if that tsunami is cca or ofc?
I found some 2/0 high strand welding cable for $3ft shipped. i feel like I should jump on it lol.
Username: Deadrabit
Marionville, MO
Post Number: 2366
i saw a guy with something that looked like that. the wire was really nice. the jacket was just REALLY big. it made the wire look huge!.
i was told the monster was good. but i have no idea. i would go to vertexaudio.com and get some of that stuff from him!
Username: Poprocks
Post Number: 356
Features:
Tsunami Premium Power or Ground Cable
True 1/0 AWG Cable
Color: Silver
High Gloss, Transparent jackets
Rated at 105 degrees celcius/ 221 degrees Farenheit
Resist abrasions, chemicals and temperature extremes
Pure OFC copper windings
Oxygen Free!
Eliminates noise from the AC line
Shielding from RFI and EMI
Ferrite noise technology
24K gold-plated, oxygen-free twisted conductors
Hermetically sealed molded ends
Made up of 36 GA tinned copper wire
Rope-lay design ensures optimum surface area and flexibility
1/0 AWG cable contains and amazing 4214 strands broken down into 7x7 ropes for maximum current transmission.
Easy to read 1 foot markings make it easy to cut to size
4214 strands @ 7x7x86 of 36awg (7 ropes consisting of 7 ropes with 86 strands each of 36 guage wire)
Username: Mendonmafia
Post Number: 2027
monster is ok at best. it has plastic in the center of the wire core. supposedly a magnetic flux something or other. basically its a gimmick but the wire isint bad. i got 2 3ft runs for free with my atomic and they work just fine but i wouldnt buy it unless it was under $2 a ft shipped.
imo welding cable is the way to go if you want cheap true 1/0 some times its actually pretty flexible if you get some good stuff.
Illinois Braaap MX
Post Number: 3022
well i actually got my hands on some 2/0 and 3/0 welding cable .
Username: Yukhui
4 15 AA Havocs, Memphis 4kw!!
Post Number: 1019
A hint of irony from the cheap wire company in your link
"It is not smart to go cheap on your wires"
Username: Deadrabit
Marionville, MO
Post Number: 2367
hey colby.. i have to ask! what kind of numbers to u get with ur 4 15s?
Illinois Braaap MX
Post Number: 3024
lol nice find colby.
