BLAUPUNKT CODE,NEED HELP!!
Username: Staffo
Hello I replace the battery in my Punto: Blaupunkt 5 DISC MULTIPLE CHOISE Nomer: BP9150X3867826....... 815 IDC A09 7 607 769 150 Tank you
Username: Hay88
Post Number: 235
hi stanislav try code 4616 then if not 8258
Username: Staffo
wrong CODE
Username: Hay88
Post Number: 238
stanislav the first code was for fiat the second was standed
the only other it can be is if your first digit is a 0 or 1 then 0258
BP9150X3867826 < using the 150 would give you 2332 for fiat or
2134 for standed. you should let reg answer first see what he says.
Username: Staffo
hay88 ho CODE to try now ?? 0258 or ?
Username: Hay88
Post Number: 241
Wait for reply from reg rooster on your other post see what he says.
Username: Staffo
Blaupunkt-WERKE GMBH , BP1430X5659985.... 881 Fiat RNS3.. 7 612 001 433 , this is the number HAY88 ,pls give me code now
Username: Hay88
Post Number: 242
try code 6644
Username: Regrooster
Post Number: 3488
Single free code for personal use only
NO TRADERS ?
