Renault tunerlist code doesn't work
Username: Reesbeest
Hello I just bought myself a tunerlist radio for my renault megane 2004.
It was with code (9492) but it is not working any one an idea?
Model no 22DC277/62
T0Q582
RN277F20053486
Prod no FD0002460053486
Thanks in advance for any help.
Username: Hay88
Post Number: 183
hi Q582 = 9492 Check the numbers/letters below barcode like 7700xxxxxxxtq123 if not same write here. how to enter code if you have steering control you must use it.please let me know how you get on. thanks.
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press buttons 6 OR 5 to store. for 10 seconds
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
Username: Reesbeest
I think the code must be oke, because it is not showing "0000" again. After entering the code, btw no steering control, I press button "5" for 10 seconds, a beep is heard, and the display is still showing the "9492" and nothing happens, and last digit is blinking as if it still waiting for input.
Does this info help to solve the problem?
Username: Reesbeest
Oke Hay88 problem solved. Thanks for the info. Because after reading your reply again I tried to save the code with button "6" instead "5" and that worked.
Strange because in the user manual it is saying "5". But any way it is working now.
Thanks again !!
