Amp Problems
Username: Alien_audio
Florence, AL
Post Number: 8
I have a Hifonics BX605 amp that keeps cutting off. It's like it has to warm up or something. If I wait a while (15-20 mins) before turning the volume up it will do fine. If I don't wait, it will cut off if I turn it up loud. It cuts completely off, no red light/green light. Help!
Username: Kingandsons07
Www.kingmobi... Lincoln,NE
Post Number: 1226
right there's your prob its a Hifonics amp JUNK!
Florence, AL
Post Number: 9
True that i'm currently out of a job so I can't afford anything atm.
Post Number: 1231
see if you can sell it and maybe we can help you find a good one that you can afford
Florence, AL
Post Number: 10
The next amp is probably going to be an aq.. 1200 or 2200
Post Number: 1232
ea i think the new RD1000.1 is around $200 ship and 1750 is around $400
same build house as the V1s so there good and putting out a little more power then the v1s
Florence, AL
Post Number: 11
It mostly depends on how soon I get a job
