I've got 3 bazooka 10's I want to put into my '96 Camaro. The amp is only 4 ohm stable and bridgable. So I can run 150w rms X 2 or 300w rms X 1. How do I wire 3 4ohm subs to an amp that is only 4 ohm stable? Can I run one sub on each channel and run the 3rd sub bridged? Or am I stuck using only 2 subs or buying a 2ohm stable amp? Thanks for the help!
if you want your amp to see a 4 ohm mono load to get the maximum power, then you'd either need one more sub, to have four single 4 ohm subs together, or you can only run 1 of the subs. do this, or either get another amp that goes all the way down to 1 ohm or something.
