Anonymous | im trying to find a pre made transmission sub box for a 10" speaker this is what one looks like if you dont know http://www.diysubwoofers.org/tls/ any body got any idea's where to find one |
Anonymous | ok i am looking for one of thoes ported boxes where it isnt like a four inch port but more like a 2x10" port do you get what i am saying |
Anonymous | this isnt getting me far so if any one can tell me this, the Rec. Dims. for a Sealed Box are 0.75 - 0.85 cu.ft and the Rec. Dims. for a Ported Box are 0.85 - 0.95 cu.ft. this is for 2 10" speakers so what should the Dims. for this box be per chamber i dont know if they should be different from the ported Dims. but i dont want to screw up what i would rather know is where could i get on of these boxes under $140.00 |
Silver Member Username: Davids2004Houston, TX USA Post Number: 157 Registered: Jun-04 | If you looking for a ported box for 1 10 this is the one that I would get. Cost around 100.00 bucks+40-50 shipping unless you have a local place that carries it. |
Anonymous | well that still comes to $140-$150 and i have one at a dealer that holds 2 for that same price and im looking for one that holds 2 for less than that |
Silver Member Username: Davids2004Houston, TX USA Post Number: 160 Registered: Jun-04 | I dont know the price on this one but it holds 2 10s. http://proboxrocks.com/superbass/2-10-SPB.shtml |
Silver Member Username: Davids2004Houston, TX USA Post Number: 161 Registered: Jun-04 | Well remember sometimes you gotta pay a little more for good quality. Personally I wouldnt have a problem ever running the proboxes. They are one of the best made prefab boxes out there. |
Bronze Member Username: GrmncrsnbrVA Post Number: 16 Registered: Jun-04 | on this topic anyone know where to find some good 1 cu ft boxes pre fab? everywhere seems to be .88 or 1.25 |
New member Username: Gcs7thNY Post Number: 4 Registered: Jun-04 | I would attempt ot mkae your own i made mien a little complicated wiht sme crazy angles and stuff but it cmae out really nice i think... http://www.geocities.com/w_s_productions/subbox.html its quite simple to make if your just making a square box. All you should need is a jig saw and table saw, and screws. You should make it of 3/4 in paricle board if you do. Carpet is cheap like $5 a sq yard at an auto store some spray glue and staple gun and your all set. I'd make your box if you have time. Its a nice experience and thne you cna really be proud of your work when your done. I made my box for less than $60. I just gotta wait for hte port tubes to come in the mail and i'm all set. |
