Need some help
Username: 03exploder
Well, I just turned 16 years old 2 weeks ago i ordered 2 Type R's and a MRD-M500 to go with them, i was talking with a buddy of mine and he said that type r's would sound better in a sealed box than a ported box. Ive always heard ported was better for bass. I was just wandering what you guys think. Thanks
Username: Sploosh56
Post Number: 209
I'd put them in a sealed box. A ported box has more SPL than a sealed box. About a 3 dB gain. A sealed box is a better all around box.
alright thanks
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 725
unless you're about to learn alot about ported boxes, and build your own, i would not reccomend putting type-r's in a ported box unless you or someone else customizes it to the specs of the subs
put them in about a 1.5 cF selaed box each because you're underpowering them by 50w rms each
k thanks for help bacon.
made a name change btw
