Radio keycode for renault clio
Username: Rachel_emmamarie
Hi would somebody be able to tell me the radio key code for a 2002 Renault Clio.
PL03 MJK
chassis number: vf1cv05cf29001369
is any other info needed?
thanks for the help!
Rachel
sorry its pl02 mjk
Username: Jimx
I have just had a nightmare re-sequencing and re-setting the imobiliser on my daughter's Clio and now that it is running I still need a radio code before she will smile :-(
The Numbers on the radio are are
Bar Code No 8200029539TE560
RN259F10358948
Model 22DC259/62F
Prod No FD0501110358948
Any help appreciated
Username: Jimx
Got my code 3453 thanks to Reg Rooster Upload
Username: Regrooster
Post Number: 2663
rachel
Registered: Dec-09 Posted on Monday, December 21, 2009 - 12:07 pm:
PL03 MJK
Sorry...insufficient information.
Try emailing
restoredclassic@aol.com
and they should be able to advise you
Mention this forum
Username: Greg45
Limerick
Hi. Looking for modus code for my wifes new car that had a flat battery!!!
Model no. Renrdw 137-00
y876 security
RNRD 1340029427
product no. FD 0204410029427
8200357388TY876
8200357388
cheers greg45
Username: Hay88
Post Number: 34
greg45 try code 1186
Username: Liamtaylor
Ferbane, N/a Ireland
i need the 4 dig code for a renault van year 2002 2 seat van 2 lit and how you get the key to work thanks liam
Username: Hay88
Post Number: 211
hi g1 liam remove radio and write down all numbers/letters from below barcode something like 7700xxxxxxtt123 or the security code can be found in a small box like q123
