Box size for a 12?
BASS
I have a 12 inch Pioneer Subwoofer, 5oow. Do you know the best deminsion for this sub?
sub_guru
All depends on what type of sound you are looking for and what type of enclosure.
go for 1 to 1.5 cu ft Methoed 16 x 16 x 8 =2048 divide that by 1728 = 1.185 cu ft good luck.
mattttt
pioneer will wok prity much any were they like big spaces and small spaces ported subs can wok well so can sealed
webbrowsingiseasy
isn't it easier to go to the Pioneer website and look it up than post here and check back for answers?
just a thought....
