Wich would be thebest to use to get max pound
Username: Dubb_408
Shark city, Killafornia Us
two 10 in alpine type R (09 model) or two 15in,(04 model)kicker comp subs ran with zapco 500.1 one chan amp ?
Username: Drant19
DUB-C, TX
Post Number: 2097
if you wanna know which will get louder on the amp, the 15 kickers would due to more cone area. however, the alpines would probably sound better.
Username: Ericmb
Waycross, Georgia United States
Post Number: 229
yeah, and the kickers on a lil bit bigger amp will get very noticeably louder!
Username: Shade
Moxee, Wa U.S.
Post Number: 883
what would sound better on that amp is just 1 sub cuz it doesn't have enuff power for 2 of either of those.
Username: Ducka
Shelby Twp., MI United States
Post Number: 1273
If the kickers are 4ohm svc then both will get the perfect amount of power. I would only do one alpine if you went that route.
If you want to be louder go with the 2 kickers. If you dont care so much about being loud you will have better sound quality with one type r. A single type r can get plenty loud too.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1867
those subs and that amp? doesnt mix
Username: Drant19
DUB-C, TX
Post Number: 2102
^^^first think i was thinkin... idk how you accumulate low level kickers, the type-r's, and then a zapco amp..
zapco is worlds above those companies in terms of SQ
