Installing cross overs in the doors?
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 198
where do you suggest i install the crossover for my new set of elemental designs "e3.65i" 6.5" component set?
I have a 2000 integra gs
in doors... in the front? i have no clue?
and do i install the tweeter in the factory tweeter hole or mount it on the 6.5" driver?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10794
I would put it where the stock tweeter was
And put the crossovers inside somewhere, they could get wet in the doors
Username: Bakerj72
Post Number: 199
thanks and as far as installing them on the sub box in the trunk... stupid cuz id have to run 2 sets of wires right?
Username: Skdooley
Roanoke, VA Usa
Post Number: 143
I have a small 2 door coupe as well (celica) and I have mine behind the front kicker panels. I got adhesive velcro tape and put a layer on the rubber stuff behind the kicker panel and a strip on the back of the crossover box, velcroed them together and its nice and secure. Plus its out of the way.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10798
Right you want to put the crossover as close to the speakers as possible
