Going from spl to sq
Username: Deadrabit
Marionville, MO
Post Number: 2129
hey every one im changing over from all out spl and wanting more sq in my ride
i have aluminum cd audio tweets and M6 6.5 but that doesn't hold up to the bass.
i would like to get 2 or 3 sets of 6.5s in my doors and upgrade to something that will sound even better if it doesn't cost to much.
iv been told that the mb quarts discus are good sets.
im not sure on price for everything. what kind of 6.5 sets have you guys owned that you really liked? good for the money?
Username: Th3pwn3r
I compensate...
Post Number: 9415
Sony makes some serious SQ speakers. They'll meld beautifully with your SQ sub-stage.
Username: Insearchofbass
York, Pennsylvania
Post Number: 12309
Do not get the mb quart discus they suck I had them.
Username: Wickedbass
Nashville, Tn
Post Number: 883
So now that you have accomplished your goal of smashing the 160db barrier you are now going for SQ???
Oh wait.......
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 841
Pics of dblk 160
Username: Deadrabit
Marionville, MO
Post Number: 2130
i didnt get 160. i ended up tuning it low . at 156 with 3300 watts and a lot more to gain. but the season is over and im not going to compete next year
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3906
are you gonna change your substage? If not then you will not have a sq system. You will have a spl setup with a lot of mid/highs. Interested is some high end Onkyo tweets. Ecoustics special $10/pr. lol j/p If you are serious about going to a SQ setup... you are already going at it wrong by even considering cheaper brands of comp sets. SQ can be more expensive than SPL...
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7258
can be more expensive?
it is a hell of a lot more expensive.. and install is even harder
do your homework before you even start buying stuff
problem with SQ i've had is constantly changing equipment until you find what works best for your cars acoustics and trying to get staging/imaging correct
Username: Van_man
Boston South, MA
Post Number: 4991
SEAS: Lotus 7" mid, 8" midbass, Lotus Tweet
or just run one of your subs at 250 and 3,000 Hz for midrange
and one at 100 and 250 Hz. for midbass.
Then throw some parts express $8 horns under your dash.
Post pics..Always interested.
Username: Frkkevin
Post Number: 7259
i would never run a 7" midrange driver.. if you have an 8" mid bass driver.. go with a 3.5"-4" midrange
Username: 813thumper
Tampa, FL United States
Post Number: 20
whats your price range? cuz i could suggest Focal which are AMAZING speakers that produce the highest quality sound you will hear, but its gonna take a big chunk of money.
Username: Drant19
DUB-C, TX
Post Number: 2068
talk to ExigeAudio about the CDT midranges.
supposed to me some really great midranges, and he will give you a h3ll of a deal as always. And you already got some good midbass speaks so i would say keep em, deaden your doors like crazy and build pods for the mids n tweets
Username: Frkkevin
Post Number: 7260
i'd upgrade to some 8" mids real;y... 6.5s never could cut it
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 3156
I know a few people who could never get a good score, so they claimed they were just going to do SQ.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1750
i agree with nick
vid of your 156 on 3300 watts
Username: Treez
Its not loud til it he...
Post Number: 435
2-6 sets of components for an sq set-up is an overkill...
813thumper, focal are amazing drivers, but they do NOT produce the highest quality sound... IMO
Username: Frkkevin
Post Number: 7263
your going to put yourself into a harder task than hitting your 160 goal
that is if you know what SQ is..
if your definition is just loud and clear.. its not SQ.. and from what I'm seeing.. thats what your looking for
Username: Tejcurrent
Post Number: 1945
^x2.
If you are just looking for multiple sets of components to keep up with your sub stage that is not sq. If you're tired of spl after one season, you'll grow tired of sq even sooner.
Username: Frkkevin
Post Number: 7266
especially seeing as in SQ the fail pic is always lurking around the corner
lots and lots of trial and error
Post Number: 21
Treez, I have not heard another set of speakers perform in any way like the Focals but maybe you know of others? I would really value your opinion.
Username: Frkkevin
Post Number: 7267
its all dependent on install.. you can have a 2000 comp set and it sound worse than a 100 set
Username: Mixmastaspig
Team RD, Canada
Post Number: 2066
SQ is brutal.
My buddy paid $10,000 CDN (not joking at all) and he got:: 3 cases of sound deadening, 3x10" hertz subs in a custom fibre glass box molded around the rear of his trunk the two side subs are regular while the middle is inverted, hertz 3-way fronts with customs pods, hertz 3krms sub amp, some fancy Audio Control unit and the hertz 140.4 amp all with a sweet custom install, tuning, amp rack/rear sway bar set up...etc and his car was in the shop for a month while it was worked on.
His1st compition for rookie SQ he got 5th place out of 7 people....he did win the peoples choice awards though.
SQ is a beast in its own rights.
Username: Deadrabit
Marionville, MO
Post Number: 2131
so now u don't even believe in getting 156
im not lookin for SQ for comps or anything that amazing, just an up grade from what i have.
Moneta, Va Usa
Post Number: 1777
yes i dont believe you gettin a 156 sealed on the dash, on the TL
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 92
speaking of SQ, i was at a car show the other day and i saw this truck with 4 hertz 12s and 8 hertz 6.5s in the box.
I asked him what amps he was running. he replies,"kenwood." Then i ask myself WTF? Why spend all that money on sq subs/speakers then power em with chitty amps?
