Deadener
Username: Ducka
Shelby Twp., MI United States
Post Number: 1196
I'm looking for some good, yet relatively inexpensive deadener. Whats good? Edead, dynamat, what else is available.
Username: Mpinto19k
Dallas/Fort Hood, Tx
Post Number: 281
I went with Second Skin Damp Pro with mine and am very satisfied, never heard the regular SS compared to pro but this site helped me make a choice.
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3901
fatmat is great for the price. Ebay can hook you up.
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 836
i'm planing on to use 2 or 3 layers of Second Skin thou out my whole cab and the spay in bed liner for the bed of the truck,
and has anyone used spary in bed liner or Deadener under the truck?
Username: Tejcurrent
Post Number: 1944
I used Spectrum. You need to spend plenty of time prepping the surface and masking off overspray areas.Remove all debris and oil/grease first, otherwise it flakes off.
I cleaned one spot, it's holding perfect, left another dirty and it flakes off in 3-4 days.
I'll never use anything other than Second Skin.
Post Number: 838
tory how much does it make a diff with Deadener to with out? i'm really hoping to cut out road nosie/exhaust nosie?
Username: Hittin1
Post Number: 3902
That is it's purpose. Should make quite a difference.
Post Number: 842
lol yeah i just want to know were to put my hopes at,
Username: Ducka
Post Number: 1197
Im thinking either fatmat or eDead. Which should I go with?
Username: Dustin3
D&L Audio Tech.Dustin
Post Number: 5104
go with edead Kevin. Can't go wrong with it.
Username: Hittin1
Post Number: 3911
Kev. I can say that Fatmat does it's job..Here's my way of showing you the difference.
http://www.youtube.com/watch?v=DKn9in3aN-U&feature=channel_page
1st vid is my setup before the 5750 and fatmat. was added. Was doing 147's and notice the flex problems..
http://www.youtube.com/watch?v=BynSXTkHCsU&feature=channel_page
This video is same song but running the 5750 and after fatmat. I was hitting 150+ and notice the difference in flex even with the added power.
Username: Snowball123
West Allis, WI
Post Number: 3134
Save up and get SecondSkin. Only need one layer then. If you think about it, you'd probably be saving yourself money, rather than putting a couple layers of eDead in.
Username: Ducka
Post Number: 1198
Where can I get second skin from? I really dont have all that much flex... nothing like Mark's suv lol. I just want to reduce vibration and hopefully gain some all important deebeez.
West Allis, WI
Post Number: 3135
secondskinaudio.com
Username: Hdubb
Team Revolution
Post Number: 4233
second skin damplifier pro is the best mafu.ckin sh.it ive ever used kiddos. if that means anything to you guys lol
Username: Exige
CDT, Audiopulse Dealer
Post Number: 802
Second Skin wins. Don't even look at anything else.
