Car Radio Code
Username: Mehreco
Houston, TX USA
I have a honda accord 2004 and I was forced to change the battery without knowing that after that I need the code. since I bought the car from an owner, I don't have the radio code card. please help me in this regard.
Radio serial # 12193528
m.salehi2003@gmail.com
Thanks,
Username: Amilo
Post Number: 8
https://radio-navicode.honda.com/
Username: Regrooster
Post Number: 1478
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any othermake.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service.
