Got some new subs.. opinions appreciated good or bad
Username: Wackzirth88
K-town, Il U.S.
Post Number: 42
i got two 12" orion xtr pros 500watts rms each 4 ohms. i plan on running them at a one ohm load. wat ur guys opinion on this subs?
Username: Woofers4life
Lexington, Tennessee
Post Number: 91
i dont think you can run them at 1 ohm i think you can only run a 2 ohm load with D4s you gotta have D2s to run a 1ohm load.
I think it goes like this if im wrong please correct me.
4ohm coils-8 ohms and 2 ohms
2ohm coils-4 ohms and 1 ohm
1ohm coils-2 ohms and .5 ohms
K-town, Il U.S.
Post Number: 44
ur right if i had a one sub set-up. ima wire them parallel/ parallel which will be a one ohm load
Post Number: 94
ok i see i mis read i thought it was 1 sub my bad i didnt see that make sure the amp is 1 ohm stable so you dont over heat and possibly fry it.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3460
what amp,? they are somewhat of an older sub. They will handle a lil more that 500 on each w/o any problem.. I liked my old pair. I remember them being a lil punchy but that was a long time and many many systems ago.
K-town, Il U.S.
Post Number: 47
i got them on a hifonics brutus 1210d at 1 ohm. its beating alot harder than my old system ( which was two 12" kicker cvr). ill be upgrading my amp in the future but its straight for now
