Bronze Member Username: MikerandPost Number: 11 Registered: May-09 | If I got this amp... http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19264 and this sub.... http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17651 Would this setup work??? Pros? Cons? Thanks! P.S. - Sorry for all the questions...this will be the last one lol. |
Bronze Member Username: MikerandPost Number: 18 Registered: May-09 | Disregard the first post.....I have changed my mind again lol. I am going to buy this subwoofer. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17852 Which one of these amps would be best? (compatibility and performance wise) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19264 -------------------------------------------------------------------------------- ------------ http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19066 -------------------------------------------------------------------------------- ------------ http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=19346 -------------------------------------------------------------------------------- ------------ Or if you guys have any suggestions within the price range of $100-150 that would be helpful too. Thanks!!!!!!!!!!! |
Gold Member Username: CarguyPost Number: 6961 Registered: Nov-04 | If you're going strictly by the numbers, then the 3rd link is your best choice. However, don't expect quality sound. If this is your first setup, then it's a good learning experience. I can guarantee that you will upgrade some time in the near future. Most people go SPL, then SQ as they gain more experience. |
Bronze Member Username: MikerandPost Number: 25 Registered: May-09 | k thanks alot man |
