Code radio for laguna 2 2001
Username: Smartco
Hi .. I need radio code for renault my laguna 2 2001.
model no MRE1402C5871
VF1BGOCO524295213
Can you help me.
Thanks a lot
Username: Regrooster
Post Number: 6562
Sorry...this is insufficient information
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
