A good subwoofer to run off of a 2000 watt rms hifonics amp
Username: Cmayne123
Memphis, Tn U.s.a.
alright i'm looking to buy a good SINGLE subwoofer that will have high amounts of spl and that will run well off of my hifonics bxi2010d (2000rms/4000max). i listen to mostly rap and it's usually slowed so i need something that will hit the LOW notes.. price range up to about 450 or so.. so just please let me know if you guys have any suggestions on what sub i should get
Username: Poprocks
Post Number: 155
What size?
How much space do you have to work with?
And Hifonics Brutus series are known to do around %80 of rated power.
Username: Drant19
DUB-C, TX
Post Number: 1617
im guessin that amp produces ~1500-1700rms.
Username: Cmayne123
Memphis, Tn U.s.a.
well since i'm looking for lows then probably a 15 or even an 18 if i can afford it.. and i have enough room for about 7 cubic feet so i should be fine as far as space is concerned
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4091
i'd go with a dd 3518
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2613
The new hifonics amps are suppose to do right around rated power from what I have heard...but I have never seen a bench result so idk.
What's your budget? how much space do you have?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10400
Until is see tests showing otherwise i'm assuming they're the same as the older hifonics amps.... which means you're looking at ~1500w from that amp
I'd use a base model Fi BTL 18"
Username: Drant19
DUB-C, TX
Post Number: 1640
somethin that gets low...
RD alpha
AP revo
FI Q w/BP option
TC3K
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 731
What does your electrical consist of Connor?
Username: Cmayne123
Memphis, Tn U.s.a.
Post Number: 7
i've got a kinetic hc2000 running off of the stock alt
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 15001
id say a loaded FI Q will be good on that amp ....
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3288
treo ssi
ap revo
fi q
idmaxx
Aq hdc3
RD Alpha
sonance spl
many others
