Did i F@#$ up
Username: Davidmeyer
Oshkosh, Wisconsin United State...
Post Number: 35
i have a new profile ca1200 2 channel amp
want a nice system
also have 2 jlw7's
how bad did i f#@$ up
Suicide-Shifter
i amp is crap but the subs are beyond good...
Username: Godemiche
Post Number: 26
agree,,, get a refund on the amp, they are not worthy of those subs.....
Username: Pat_l
Tucson, AZ USA
Post Number: 243
That AMP will not bump those JL's at all no matter how many watts it says (i have a profile and it is no good) Those subs are very good. All in all not bad.
Robert J
i don't know much about profile amps but i'm pretty sure that there not 1.5ohms stable which is what a jl w7 is. so you really need a jl amp to power there subs because there is only a few amps out there that are compatible. you could get two mono amps stable at 1ohm and wire your subs to 1.5ohms, you won't get full power out of the amp but it will be close. look at mmats they are 1ohm stable i think.
Username: Alpinepower
Post Number: 64
Earthquake shreddars are 1.5 ohm stable and amazing, they hold the record for spl off 1 amp, but they're more than a couple of bucks.
