Box Cu. Ft. Size!!!!! NEED OPINION!!!!
Username: Kickittothacurb
Post Number: 22
Okay im getting 1 12" RE SE. I'm going to want a ported box. How many cubic feet should i make the box? Its going to be in a 00' S-10 Blazer.
Username: Mike11202
RE MT 15 VFL 200.1 , Sewell, NJ US
Post Number: 1882
http://img.photobucket.com/albums/v407/mike11202/2cubes35hz375sqin23dd.png
Username: Mike11202
Post Number: 1883
i would mount the sub up too
Post Number: 24
mount them?
Username: Mike11202
Post Number: 1885
build that box and instead of the hole for the sub being in the front make it on the top of the box, so its mounted up
Post Number: 25
oh okay. Just curious, i've never done it that way but what does that do for it? And how much different is it then just putting the box on its back? Also, are you talking about reverse mounting it then too?
Post Number: 28
Username: Mike11202
Post Number: 1886
re-read what i wrote im going to put it in idiot terms if you are putting the box on its back, keep the original sub cutout on the front and move the port to the back left side
