Overall...JL or RE
Username: Kickittothacurb
Post Number: 27
My friend and I are debating between the brands. I like RE, he likes JL. In overall quality, sound, price, SPL/SQ, which is the better brand for subs. I usually get a 12" but im speaking overall. COMMENT NOW!!!!
Username: Dsmith07
NC Http://com4....
Post Number: 913
Overall both companies are A+. JL being more expensive of course. I believe with both companies you should stay away from the lower line of subwoofers ( JLw3 and lesser ) RE SE's being as low as i'd go with RE. It all depends on how many watts and how many subs you want, also your budget and cargo space, eletrical as well.
As far as SQ/SPL
JL:
spl= w7....the w7 in JL box is supposed to be sex..
sq= w6
re:
decent SQ= SE
decent SPL= SX
nice SQ= 04/05/06 XXX
nice SPL= MT
if your running more than 1500 on a single sub though RE is more what your looking for b/c the W7 is highest rated JL sub at 1500
