Subwoofer ported enclosure
Username: Beallstar13
Post Number: 14
what would be better to do?
ive got 2 12" kicker cvx subs
should i:
have them share a chamber and port
or
have them have their own seperate chamber, but share a port
or
have them have their own chamber, and own port
port is tuned to 35hz
Username: Surferdude9371
Get loud or go home....
Post Number: 1747
shared chamber one port id only do sep for sealed box
Post Number: 1748
actually sep chamber shared port sounds good too
Post Number: 15
lol well what one would be best?
Post Number: 1751
trial and error build both see which sounds better if not id do sep chamber that way if one blows you can always block off the sep chamber
Post Number: 16
well the thing is im not building it, lol im paying someone to build for me :P
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20118
Hows the build ability of the guy building your box? You might want to keep it simple unless he's experienced.
Me? I would do separate chambers and ports.
Don't ask why. I don't know.
Username: Ami_creations
Kennesaw, Ga
Post Number: 32
Paul here is some of my work
http://www.caraudio.com/forum/showthread.php?t=390101
Diamond Member
Post Number: 20119
Didn't know he was using you Mike. Good stuff.
Carry on soldier.
Kennesaw, Ga
Post Number: 34
Thanks Paul
Diamond Member
Post Number: 20120
Your shop looks like mine did awhile back. A mess lol. That means you've paid your dues. Seeing the dust on the lense on most of the pics is familiar. Hope you wear a dust mask. MDF dust is brutal.
Post Number: 1752
id let mike choose what he thinks is best for your application
