What Subs for This Amp?
Username: Xmrbonez
Post Number: 15
i have a sealed box for 4 10"s
i do NOT want to get rid of this box right now but in the future i will either get a 4 10" ported or 2 10" ported
i have the BAMF-2000 D amp by Power Acoutik
i DO NOT want to get a new amp it matches my color scheme nicely. if anything i may upgrade to a bigger BAMF Amp.
what 4 10"s would hit best matched? it is the basic 4 chamber q-power box if you want spec.
also while i have you hear does my CD Deck/PLayer make a differance in subwoofer max volume or is that all amp?
and do you think putting my seats down would be louder than up? seems like it for some songs but not all
thank you for the great help, like always guys.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2770
get a better ,amp, box, and deck
Username: Xmrbonez
Post Number: 16
ok than
im current using
4 10" woofers(2 ma 2 kickercomp)(I know dont mix)
a 2600 watt pyramid american series amp bridged to all 4
i enjoy the sound of a sealed box, and aside from it i cant afford or have the skill to make my own ported.
using sealed
What 4 10s + amp would be a good amount louder than what i have now. 130 dbs maybe? also what would be a good deck
i have maybe 250 to spend TOPS on a amp and i would like to get my amp FIRST than my subs because this way ill notice a differance, if i blow the subs owell.
and as for a deck i dont want anything flashy or touch screen i tend to break that kinda stuff so, whats a nice basic deck preferably lit in blue, and with Ipod jack?
im sorry im smashed st pattys!
got me askin lots of questions
Username: Bumpin_hard
Post Number: 21
i tink u need 2 get sum duals, my dualz bump harder den anybodies sh1t in dis city.
Username: Xmrbonez
Post Number: 17
i had duals, not impressed
Username: Xmrbonez
Post Number: 18
does anywon got a link to s sindown like 1800D? would that be enough to pwoer 4 subwoofers and still hit hard, the lowest i really wanna hit is 120 dbs id liek to aim more for 130.
thinking a 1800D to 4 DD 10"s than ocne i get money run a pair to each
Username: Drant19
DUB-C, TX
Post Number: 1455
ditch the box.
get a new amp and subs.
dont get more than ~1200rms for the amp.
just get 2 10's, 12's, or 15's and you will get louder than a meesley 130dbs.
oh and build your own ported box. built to the specs of your NEW subs
AQ1200D
2 Type-Rs or RE SE's
^^^^you'll be impressed with either of those setups
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14785
i say start over from scratch ...
