Bought to buy lend me ur opinions AudioControl EQL
Username: Mj23dynasty
Alpine ida-x001/2 dd 2..., Woodlawn Por... USA
Post Number: 2015
Just discovered the Ca classifieds love to shop there lol...
Picked up kickerzx650.4 -175 shipped lnib
Python 990 105 shipped
And next up this audiocontrol eql for 60 shipped its used and I don't think its the newest model bcuz I looked up the specs and logo placement is different on the one that's being sold now. Lend ur reviews and opinions on the purchase thanx guys.
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14774
price is cheap but u do know what an eql is for right
http://www.audiocontrol.com/t34/5248/Trunk-Mount-Equalizers.html
all it really does is adjust certain freqs - its like an external eq
1 input 1 output ...
Post Number: 2016
ok so its not a normal eq??? i just want to get the best sq from my cdts and my subs as i can get and i have a crappy jensen flip out sooo would this unit be a good fit or not.
Username: Nd4spd18
Philadelphia, PA
Post Number: 10084
No EQ is useful unless you have the equipment to properly tune it.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6300
i'd start at the most important portion.. the headunit.. dump the jensen
Post Number: 2017
Well I was getting it tuned @ a pretty good shop best around here... and what deck wud u suggest I want a tv one thts not too expensive which doesn't mix but give me a few suggestions I was looking into the clarion unit I forget which model it retailed for 485 or something round there... 440 maybe...
Username: Basebalz13
Moneta, Va Usa
Post Number: 1153
get a alpine h701 with the c701, take it to that shop thats the best around, have that tuned, also your looking to get the best SQ outta them comps, its not all about having lots of clean power and a big EQ because all the EQ will give is lots of "mechanical" sound, its all bout placement which takes weeks to do
make sure ur mids is in its best enviorment, well where is ur mids going, kicks or door?
then after u got ur mids placed and in a good enviorment then its time to start playing around with the tweets which envolves some velcro and lots of ridin around changin location till ur get them phased in correctly with the mids also this is with out EQ
Username: Rovin
Post Number: 14780
agreed with these guys - if u have a lame HU then the whole set will sound lame
remember the HU is the brain of any set ...
Post Number: 2019
Well I asked u guys to reccomend a decent tv unit with good SQ...
