Autoradio CODE
Username: Pedroqc
Hi,
I need a radio code to Peugeot 206 autoradio. Radio model number is PU-2325A(B) and serial number is CL041010292463
please help me!
Username: Hay88
PortsmouthUk
Post Number: 1932
Pedroqc
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
