Mtx ta81001
Username: Lightinfoot
Ponchatoula, La Us
Post Number: 7
Is the mtx ta81001 a good amp or not?
and if so how many subs could it push?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9983
MTX amps used to be good. Newer ones are not so much.
Ponchatoula, La Us
Post Number: 10
k thank you m.s.
Username: Tigger76
Portland, Oregon
I have 2 mtx 81001's hooked up to 4 mtx 7500's and the amp does great and they are all wired out to a 1 ohm load and the gain is set at half and the system pounds!!!!!
Username: Poprocks
I like the MTX TA series amps if you can get them for a good price,if paying authorized dealers cost there are lots of other companies out there.
A amp doesn't read subs it reads a ohm load,so as many as you want just make sure the amp will push the subs RMS.
Ponchatoula, La Us
Post Number: 11
k thanks pillip
Username: Ton
Post Number: 184
My last install was 1x 81001 hooked up to 4x 7500 12"
and it was a nice setup.
An very underrated Amp, mine was tested at 1958Wrms at 1ohm and was very solid.
Username: Dsmith07
NC Http://com4....
Post Number: 905
you could run however many subs you would like, for a trunk car i'd run 2 12's or 2 15's but for an SUV maybe 4 12's or 4 15's
