Aq1200D
Username: Snacks
Quincy, Florida USA
Post Number: 155
anyone have/had one? im planning on getting one this weekend.
pros/cons?
Username: Deadrabit
Marionville, MO
Post Number: 1271
great amp. get one. i have an aq2200 for sale . 300 bucks
Username: Snacks
Quincy, Florida USA
Post Number: 156
thats a little over my price range haha but thanks. im definitely looking forward to the 1200
Username: Snacks
Quincy, Florida USA
Post Number: 157
also, sorry if its a dumb question, but would I be able to run it fine with a stock battery? im putting it in a 98 ford windstar with 4ga wiring.
Username: Snowball123
West Allis, WI
Post Number: 2193
should be fine, but I would use 1/0 just to be safe.
Username: Snacks
Quincy, Florida USA
Post Number: 158
haha FML, i just put that 4ga in not even a month ago... im gonna wire it to 1ohm on 2 DVC kicker cvrs, would that not drop my voltage or anything like that?
West Allis, WI
Post Number: 2194
cant really tell you. idk what size your stock alt is. I'd say at least do the big 3.
i think you meant to say FTL right?
Username: Snacks
Quincy, Florida USA
Post Number: 159
nah, fml. f*ck my life. i guess ill have to do some research cause im not 100% on that whole big 3 thing.
West Allis, WI
Post Number: 2196
sounds like it's pretty easy. Once I buy my new alt I'll be doing mine also.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2513
AQ1200 only excepts 4 ga.power/ground. run 4 ga. after fuse or trim 0 guage to fit.
dBLK.. <biting> $300 shipped? whew. wasn't easy.
Username: Van_man
Boston South, MA
Post Number: 4620
I got the aq2200 and love it. Never even gets warm.
Mark with a k... Jump on aim...quick Q..
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2357
No problems with my AQ1200D, great amp. 4ga is plenty for that amp, 1/0 would be way overkill unless you plan on getting a bigger amp in the future.
Username: Hittin1
Post Number: 2514
Mark with a C, i'm on aim... f*ck it, i'll be in E- Chat room.
Abraham-
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
Snow- FML= Fu<k My life
Username: Nd4spd18
Philadelphia, PA
Post Number: 9770
Installed a few, great amps.
4 gauge wire is fine for it. With an amp that size big 3 won't give much of a benefit unless you're putting in a HO alt.
Username: Jtown
Texas
Post Number: 3572
You won't need 0ga to be safe, that was an incorrect statement. 4ga is just fine for that amount of power.
as M.S. said, you also won't need 0ga for the big three either, unless running multiple amps, i.e. more power.
Username: Snacks
Quincy, Florida USA
Post Number: 160
you guys are awesome.
