Kicker problem
Username: Blkbville04
Monclova, Ohio US
Post Number: 48
Ok so my friend has a 97 mercury sable ls and he has a crunch p1100.2 and a crunch p500.2, the 1100 pushin a L5 and the 500 pushin 2 comps. The problem is when his trunk latch touched the locking latch for the trunk lid, all 3 subs go into a low frequency and go at full volume until the trunk is opened again, then everything is smooth. If just the L5 is hooked up, it works fine, if just the comps are hooked up, it works fine, but as soon as they are all hooked up it does it again. All grounds have been double checked just in case and everything is hooked up right because as long as just one amp is pushing subs they work fine. Any ideas??? Thanks guys
Username: M0nstar
Toledo, OH U.S.
Post Number: 79
fail.
L5= fail
L5 + 2 comps= ^ x 2
if they're different size subs can you hit your friend for me?
crunch amps.
well 1st how are the amps grounded,
what wires are in your trunk lid (liscense plate lights, brake lights, etc)?
probably loose + wire(s) somewhere.
i guess the best thing to do is sell everything. then you won't have ANY problems at all.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6184
lmao @ things you see in the hood..
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2629
Please provide us with pics of this instsall so we can help you solve the problem
Username: Surferdude9371
Get loud or go home....
Post Number: 1627
sounds like a power wire is getting grounded when you shut the trunk
Username: Tatonka
Post Number: 2631
My friend G-Trap would tell you that just means you got "sum scary slap, nig"
Username: Southernrebel
Post Number: 7223
Um...is the ground run to the trunk lid?
I see that kind stuff show up here at the shop from time to time.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9529
lawl @ nig rigged systems
Username: Wickedbass
Nashville, Tn
Post Number: 347
Yes, pics please. I wanna see this.
Username: M0nstar
Toledo, OH U.S.
Post Number: 82
wicked and nick V.- you dont want to LOOK at the install, you want to LAUGH at it. lol
Nashville, Tn
Post Number: 348
Well yes, admittedly a good laugh would be great right now but a pic of the install would help to diagnose the problem. It can be describe to us in words all day long and we still might not get to the root cause of the problem. But a pic could make the culprit blatantly obvious.
Username: Frkkevin
Post Number: 6187
is this his security setup?
Username: Tatonka
Post Number: 2632
x2
A few pictures always helps identify the problem. I'm not just here to be a jerk, I'm also here to help :-)
Monclova, Ohio US
Post Number: 51
lol well i dont even know where to start. There are no grounds running to the trunk lid at all, everything is weird its insane, i think he's just gonna take the comps out to avoid problems. Ill get some pics before he takes everything out
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 3138
Make sure nothing is pinching the power wire anywhere. Sounds like the problem to me
