US Acoustics USB-4064 underrated?
Username: Cozce
St. Louis ILLside, Pronounced: ... U.S.A.
Post Number: 470
http://www.caraudioclassifieds.org/forum/showthread.php?t=5121
Zed designed amp
65x4 at 4ohms
So tell me, underrated or not? Anybody know what it's actually rated at? 12.5, 12.9, 14.4?
If it's underrated I will highly consider buying it.
Username: N2audio
Lawrence, Ks USA
Post Number: 1713
I think that's an Asian amp top to bottom. There's a usb2080 on ampguts that looks very similar on the outside to that 4065 but it doesn't appear to have had anything to do with Zed Audio and it also says USX2080 on the board.
If the seller had it open to see the inside why isn't there a picture of it??
I'd want to see the inside before I bought it. I don't think it's a Zed amp.
The seller might honestly believe it is, or I may be wrong -- either way, I'd want to see it.
