LOST RADIO CODE FOR RENAULT CLIO 1.5 dCI 2OO1
Username: Ajran
Hi,
can anyone help me, I changed battery and my radio now requires security code.
I have Renault Clio 2001. I like this radio and I wouldn't like to change it.
Model No. 22DC229/62T
Prod No. FD0101390022887
RN229F10022887
TOQ584
thnx
ajranko@gmail.com
Username: Regrooster
Post Number: 337
Eki Ajran
Username: Ajran
Posted on Wednesday, January 07, 2009 - 01:31 pm:
Hi,
RN229F10022887
TOQ584
You code should be 9434
Username: Ajran
I have attached radio in my car and apropriate cables. Also I input code 9434, end don't work :-( .Is it possible that I made some mistake, or could radio be blocked somehow? Maybe, it is necessary to appropriate procedure or some another code? Thanx for patience.
Post Number: 338
If you have already entered any wrong codes then it might be semi-locked.
Leave it SWITCHED ON ...UNDISTURBED for as long as it takes to reset itself.
