Painting the dust cap
Username: Jtown
Texas
Post Number: 3410
What is a quality paint that I could use to paint the dust caps, if possible, on my ss Rl-is? I purchased an rl-i from Paul off of E and the second directly from ss, unfortunately they turned out to be slightly different colors, lol. it's not really a problem, I just would like them to be the same color (preferably black, since that is the theme of my install).
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6100
i would just do thin coats of duplicolor
Username: Jtown
Texas
Post Number: 3415
well I got to thinking about it, is the paint going to offset the weight of the cone? I don't want any coil or cone rub due to painting the dust cap.
Username: Frkkevin
Post Number: 6105
I doubt that would happen.. It won't add barely any weight unless you use an excessive amount. Even then I think it would only affect a much smaller speaker.
As I said above, just do thin even coats.. Just as you would paint anything.
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 3091
If you dont prep you might as well not do it FYI
Username: Jtown
Texas
Post Number: 3417
Well Capps, what do you suggest is the best way to prep the aluminum dust cap on the ss subs?
Andrew Capps, NC US
Post Number: 3095
scotch brite the cap lightly (where the marks are visible but not deep at all), then take greased lightning or another degreaser to it, then clean with soap and water and then let it air dry then do light coats of paint, 2-4.
Username: Jtown
Texas
Post Number: 3418
by marks, you mean the marks that the scotch brite will cause?
thanks for the tutorial Capps.
Andrew Capps, NC US
Post Number: 3097
yeah, the scotch brite needs to scuff it to give the paint something to grab but if it goes too deep you wil see the marks after it is painted.
FYI, Thats basically how I prep anything I paint like that.
Username: Bernymac
Phnom PenhCambodia
Post Number: 4546
you could use adhesion promoter.
Username: Jtown
Texas
Post Number: 3419
what is that and what would it do Berny?
Andrew Capps, NC US
Post Number: 3100
I do... I use Bulldog adhesion promoter. It makes paint cling to just about any surface
