Voltage barly droppin lights,dimming bad??
Username: Wfbass
Stephenville, NL Canada
Post Number: 60
latly ive noticed that when i turn up my system my lights dim very bad, like id say 50% at least. when i look at my cap its only dropping to 13 volts?? yes i have the big 3 done, 1/0 gauge wire, good batt, ho alt. i cant think of what could be doin it or why my lights are dimming yet my volatge is fairly stable? i got a rf 10 farad cap to which is where iam gettin the reading from...maybe this in inacurate iunno. i dont think it would that off though. anybody got any suggesions to why this is happening?
thanks for anything in advance
Username: Deadrabit
Marionville, MO
Post Number: 1201
well i am guessing ur getting 13 volts to the amp but not anything else. (i might be wrong on that cause i don't use caps)
what amp or amps do u have?
u could have ur gain high and after u start clipping ur efficency goes to crap
what kind of alt do u have? this sounds interesting
Username: Livin_loud
COD4 Addict
Post Number: 2844
i don't believe caps show battery power... just the power they have
Username: Deadrabit
Marionville, MO
Post Number: 1202
is anything loose?
Username: Crayola0
Portage, Wisconsin
Post Number: 2552
^^^^ ur mom after i was done with her
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 439
haha
Username: Tejcurrent
Post Number: 1641
I would check your voltage up front with a multimeter, then check the back at your amp. I'm willing to bet your cap isn't showing the correct voltage. I'd try that first so you have a good idea what's going on where.
Username: Wfbass
Post Number: 61
will do troy. i got a rfT2000 runnin on 2 ohms. my gain is little over half. mcr alt 200 amp. something could be loose besides blk's mother to ill double check that for sure, thanks guys
Username: Van_man
Boston South, MA
Post Number: 4532
check all your grounds. If it just started latly, then something changed. Check the big three gronds and the amps grounds.
Username: Nyyfan13
Http://lowdo... Join My User...
Post Number: 10953
"^^^^ ur mom after i was done with her"
Lol, I chuckled at that one.
Username: Deadrabit
Marionville, MO
Post Number: 1211
hahahaha! if u really new my mom u would prolly laugh even harder!
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 3082
Hey BLK,
Username: Nd4spd18
Philadelphia, PA
Post Number: 9421
Even a small change in votage is noticable in the lights. HO alternator is a possible fix if it has a better than stock voltage regulator. But even those are often not fast enough.
