True pan, baltic birch,.... maybe even mdf2?
Username: Deadrabit
Marionville, MO
Post Number: 1138
i am going to get some wood tomo for my next wall job. i don't really want mdf because i want soemthing stronger and lighter if i can.
today a man told me that mdf2 is just like mdf but stronger.. but the way he talked i am thinking it will also weigh more.
i know that baltic birch is good, but cost a lot
truepan... i dont know anything about it really. but he said it was really light and stronger than mdf..
any one know about truepan?
he said if i can fiberglass resin it would soak into the truepan and that would be the best thing i could ever use.. .. only what he said.
Username: Surferdude9371
Get loud or go home....
Post Number: 1564
its trupan light your talking about its as strong if not stronger than mdf and about 30% lighter its what fisher uses for his boxes
Username: The_image_dynamic
San Diego, California
Post Number: 4920
Trupan Light is 80% the weight of MDF but not as strong. That's 20 pounds less per sheet. Trupan Ultra Light is 60% the weight. The main advantage is it is very easy to cut and router. It also sands mirror smooth.
Username: 420alldaylong
Post Number: 3899
http://www.fishercustoms.com/products.html
Username: Deadrabit
Marionville, MO
Post Number: 1141
i have been on the fishercustoms site before.that doesn't help anything.
the guy at the lumber place told me trupan was stronger than mdf.
how does it hold up to baltic birch
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6006
while your in the store just test em.. buy the one that don't break during your test :P
Username: Van_man
Boston South, MA
Post Number: 4479
A few guys who do very well make their walls from this stuff.
http://www.huberwood.com/main.aspx?pagename=advantechflooring
and lighter and stronger usually dont go with cheap.
