Help with box for HDC310s
Username: Mark872
2 Type X 12s, Hughes S..., Texas
Post Number: 307
I need to know if i can fit 2 HDC310s in my trunk. Their site says the recommend 1.5cuft per sub. Is that after, or before port displacement and stuff? If after, i need to know how much volume to subtract from the box because of port area? If i cant get a 3cuft box to fit, how small could i got for theses to still perform well?
Username: Insearchofbass
Post Number: 11043
Thats after sub woofer and port displacement. Using 3.00 cf after sub and port and making the port 3 high 16 wide 13.25 deep will give you a 40 hz tune. That port adds .48 port displacement. I dont know what the subs displacement is but you can email DJ at audioque.
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2507
they will preform well with as low as around 1.2 per sub
Username: Mark872
Post Number: 308
Holy sh*t man, .48 displacement just for the port? What would you guess for the two subs together to be? Its really looking like i want be able to fit these.
Username: Dlavante
Tigard, Or USA
Post Number: 124
subs don't displace very much volume.. probably around .25 for both subs
Username: Mark872
Post Number: 310
Alright thats not too bad I guess. So say if i was using a sealed box calculater. I would just need to make it roughly .75 bigger than what i need?(.48 for port, and .25 for subs)
Username: Dlavante
Tigard, Or USA
Post Number: 125
something like that, but keep in mind that if you make the box .75 ft^3 bigger you'll need to re-calculate the port and the volume that it will displace
Username: Mark872
Post Number: 311
Well my maximum dimensions i can have in my car is 11.5h x 28w x 23 depth.
Post Number: 11049
Thats 3.29 cubic feet without the subs and port.
With a port 3 high x 14 wide x 15 deep for a 40 hz tune .48 port displacement minus about .25 for the subs displacement 2.56 cubic feet net
