Battery Group Sizing,
Username: Snowball123
West Allis, WI
Post Number: 1646
How are you supposed to know what group size battery will fit in your car. Car is an 02-04 Dodge Dakota V6.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8926
27 or smaller
West Allis, WI
Post Number: 1649
how do you figure it out though? Just look it up or what.
Username: Wickedbass
Nashville, Tn
Post Number: 96
Here you go man, maybe this will help. A chart of the MAX physical size each group batt can be.
http://www.rtpnet.org/~teaa/bcigroup.html
Username: Nd4spd18
Philadelphia, PA
Post Number: 8933
Put the car into autozone.com and look up battery.....
Just don't actually buy one from them cause they sell shitty optimas
That will give you the largest one that fits.... you can always put in a physically smaller one with not much work if it has more power or something. For example a size 25 odyssey verses a size 27 regular battery.
Nashville, Tn
Post Number: 97
^^^Agreed. An optima yellow top from autozone was the first battery I ever bought for system related purposes. I dont know if it was just the store where I got it or all optimas in general but I was never impressed with it.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8935
Thats optima for ya. Only thing those yellow tops are good for is deep cycle, current capacity and discharge rate sucks.
