Help...
Username: Str8killaaaa1337
Kissimmee, Fl
Hey I was wondering what do you think i should get the kicker 06S12L5-2,08S12L54,or 08S12L52 and I was wondering what amp should I get with them. Its for a 2001 dodge durango with a Kenwood KDC-MP238 head unit.
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1751
L5 are ****! what is your budget and goal sq sql spl
sq=quality
sql=quality loud
spl= holy ****
Username: 04redmach1
Es DEALER, GA USA
Post Number: 2429
LMAO!! I love it Scott
Kevin
Kissimmee, Fl
like 180 each...
Username: Talon01
Post Number: 1755
whats the goal sq sql spl but for that price i am going to quess sql. option are going to be
dc audio lv 3 dcsoundlab.com
rd sonance rdaudio.net
aq sdc2.5 audioque.com
what type of music do you listen to?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8905
Just about anything from a decent brand is better than a L5
Kissimmee, Fl
i listen to rap/hip hop and what the l5 are really that bad?
Username: Drant19
DUB-C, TX
Post Number: 1315
yes, yes they are Dave.
Kissimmee, Fl
oh ok, well do you guys have any advice then for good subs? My budget is about 200 for each sub.
Username: Snowball123
West Allis, WI
Post Number: 1622
Are you just going to run off stock electrical?
Kissimmee, Fl
Yes. I'm pretty sure I will be,
Username: Talon01
Post Number: 1766
the dc and the rd would work for ya.
Kissimmee, Fl
Well I'm pretty new to this is there anyway you can just tell be a good system(amp,subs,wiring) for about $600.
Username: Loc_out
Team RE XXX
Post Number: 2649
Why not a pair of RE SE. Those would work if you are planing to run them off your stock elec.
Kissimmee, Fl
Post Number: 7
Do you have a link?
Username: Talon01
Post Number: 1768
do you mind used equipment if not i have a package deal for ya. sub amp and wiring for 400.00 plus ship.
mtx 7512-44 in a enclosure
mtx ta 4501 amp
0 guage amp kit
Diamond Member
Post Number: 22713
scott knows wassup. i'd take his deal. he must be selling so cheap cause its the holiday season.
also scott is a stand up guy. i vouch for him. if chad lee vouches for someone then that person is very trust worthy.
Username: Talon01
Post Number: 1769
thank you chad. i have so much extra equipment sitting around. it is time to outlet price the stuff need room for the new project coming.
Kissimmee, Fl
Post Number: 8
Thanks for the offer but I rather just buy new stuff sorry. Are Kenwood subs any good?
Username: Talon01
Post Number: 1771
i am not a big fan of kenwood
Kissimmee, Fl
Post Number: 9
Oh well what are some good subs for around 180?(each)
Username: Nd4spd18
Philadelphia, PA
Post Number: 8919
I would contact kevin holden about some RD audio classic or sonance www.rdaudio.net
You won't find a better price than his
Could also get a Audioque SD2.5 www.audioque.com
But IMO that sub lacks low end response. Still tons better than keeker or kenwood though.
Kissimmee, Fl
Post Number: 10
Thanks.
