Oil light problem
Username: Hotnorm
Lasalle, Quebec Canada
since i connected my remote starter with the oil sensor input my oil light lights up dimly , my motor is a 2.7 liter dodge and the oil sensor is a single wire model i checked the voltage coming off the sensor before connecting to it, it indicates 12 volts when motor is off and 3 volts when motor is running , does anybody have suggestions on how to fix this problem , i unplugged the tach sensor wire since the input seemed bad after 1 year of use, the remote starter works fine on the oil sense.
