Kinetick2400 question
Username: Cplaya280
Pennsylvania USA
Post Number: 979
im getting a kinetick 2400 and the guy im getting it from is sayin he hopes i have a good alternator for this battery? i dont understand why having a good alternator for the battery has to do with anything and input. Could this battery actully hurt my alternator?
Username: Brewsky
Prince george, British colu... Canada
Post Number: 134
works better if u have a good alternator but if u run your batts togeather its not tooo bad either would be better with more voltage but if u dont fuuuuuck it :-) im going to be running 2 batterys in the back and 1 under the hood off my stalk alty
Username: Deadrabit
Post Number: 809
i have a pair of kinetic 800s with a stock alt and starter battery.
my starter battery gets REALLY hot.
i have a new alt but i have not taken the time to put it in cause its working fin.
i know a guy that has had a 2400 on stock everything and ran it like that all year with no problems at all.
Username: Bonhamd
Post Number: 1207
maybe he means a good alt for the saz1500d?
Username: Nd4spd18
Northwest PA
Post Number: 8511
He probably means that the battery by itself is not enough to make a good electrical system you need a good alternator also.
And that is correct.
