Naledge!!!
Username: Crayola0
Portage, Wisconsin
Post Number: 2488
where exactly did u run the power wire cause im looking for the hole but cant find it
Username: Th3pwn3r
I compensate...
Post Number: 8647
Ugh, check the firewall under the carpet.
Username: Naledge503
Portland, Or
Post Number: 4151
I just went to take some pictures but my batteries are dead in my cam. So I'll try to explain.
In the engine bay there is a hole just to the right, and level with the battery tray. Thats where I ran my wires through.
