Stetsom 2k6d
Username: Bonhamd
Nobody fuccks, With the jesus
Post Number: 987
what would this amp be comparable to?
i searched in google for bench tests and what not but didnt find much.
can this thing take .5 ohm before rise?
any help is much appreciated
Username: Bonhamd
Post Number: 988
bueller
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2405
I'm not too sure but i think Sean own one.
Username: Insearchofbass
Post Number: 10240
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=001057;p=0
Hey guys, I am new to this site, but I was told to bring my amp over here and there would be a better chance of it selling.
I have plenty of refs over on caraudio.com's forum, where my name is SeanDub.
Here is what I posted over there:
"Okay, I'm thinking I need a little more power, so I'm looking to get an amp that'll do around 4 - 4.5kw. So, I'm going to post up my 2k6 here and see if there is any interest. I'm thinking about picking up an IA 40.1, pair of 20.1s, pair of AQ 2200s, Memphis 4kw, AB 400.1, AB 500.1, Stetsom 7kd, etc, etc, etc. Therefore, I'd be willing to do a trade + cash for one of those amps if anyone is interested.
There have been some doubts about this amp, and questions about it's reliability for daily use. I can assure you that I have used this amp daily for approximately six months, and I have not had any issues. Also, about 5 of those were at 0.5 ohm, and the other was at 2 ohm. Below are the Stetsom ratings and my own personal clamp test results. The only issue I've had with it is that it is kind of loud. The fan inside of it runs loud enough to be heard when the music is playing at very low levels, but can easily be droned out, and also it can be covered up if placed directly behind a seat.
Ratings from Stetsom:
RMS Power @ 13.8V <0,9% THD Mono 2 Ohms: 3000 Watts
Mono 4 Ohms: 2200 Watts
Mono 8 Ohms: 1200 Watts
RMS Power @ 12.6V <0,9% THD Mono 2 Ohms: 2600 Watts
Mono 4 Ohms: 2150 Watts
Mono 8 Ohms: 1050 Watts
Minimal Input Impedance: 0,2V
Total Harmonic Distortion: < 0,9 % THD
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Input Tension: 9 to 16V
Power Consumption: 3,3 to 240 A
Dimensions : 70 x 280 x 330 mm
My clamp results:
Basically I just spent an hour trying to host or attach this **** excel file.
I can't do it, so if someone would like to do it for me, I would greatly appreciate it, or I will email it to everyone.
I tried it as a Word doc, but couldn't get it under the size restrictions.
I tried it as a .bmp (Paint), but couldn't beat those restrictions either.
And I couldn't find a site to host an excel file.
Price: I'm looking for around $600 shipped + PP fees.
Let the lowballing begin."
As far as my clamp results, I also posted a few of the highlights from the testing:
When wired at 0.5 ohm nominal:
2924 watts @ 0.95 ohm
2900 watts @ 0.99 ohm
When wired at 2.0 ohm nominal:
1863 watts @ 4.57 ohm
1247 watts @ 6.74 ohm
Username: Bonhamd
Post Number: 989
thanks - so this is saying that he wired to 0.5 ohm before rise and ended up close to 1 ohm after rise? and he then saw near 3K?
what amps are comparable?
thanks
Post Number: 10242
My brothers rd 3250 can do .50 ohms and at .875 they are saying it puts out 3750. Im pretty sure they can run at .50 daily with no problems but check with Steve at RD or Kevin.
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm <0.1%
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 590(L)mm
Username: Bonhamd
Post Number: 990
ya i talked to steve today and i think i am getting the 3250.1 but i just wanted to keep my options open
Username: Mixmastaspig
Team RD, Canada
Post Number: 1794
I thought Stesom was really poor for daily listening and overheated a lot?
I've read that a few times but I can not confirm it as I have not used them before but I hear they area absolute beasts for competitions burping wise.
Post Number: 10243
My brother actually runs two of the 3250's strapped. They seem like solid amps.
Post Number: 10244
And Lowlife I dont own one of those Stetsom 2k6d's. They are too expensive for me. And I did hear about some issues daily Mike but I never checked to see if those issues were legit. But I know some guys who would know. So id make sure everything was ok there before I even considered buying one.
Username: Bonhamd
Post Number: 991
ya im set on the RD3250
im going to get buy it next week
thanks for the help
Post Number: 10245
Your welcome.
