Peal&Seal
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2304
I plan on using peal and seal on my door this weekend have you guys had any problem with it?
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7980
agarrate morro que ay te voy
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 3690
none at all. the "smell" is non-existent, don't let people tell you otherwie.
the cisco kid
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2305
Orale el lil rob.... I used some before and like how it worked. Just didnt know if it would smell after some time.
Username: Exige
CDT, Audiopulse Dealer
Post Number: 552
yes, I recently redid my panels and had to rip it all out. it was pealing off massively. go with raammat or something of quality. you'll be much happier that you did.
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2306
Too cover 4 SUV door how much would i need??
Diamond Member
Post Number: 21859
i was gonna tell you to get stinger road kill from chad geary. they give me a sheet of that stuff for $20. 6 sheets should cover the everything since you only need one layer. but the problem is classic is closing this weekend.
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2307
Wait 20 bucks??? Will they be open next weekk if they are I wouldn't mind waiting
Diamond Member
Post Number: 21860
no they are closing down. chad geary is gonna go work at another shop near classic autosound.
now as for 20 bux a sheet, well thats me and berny's price. lol. if you want some then you gonna have to ask me or beny to go buy you some cause i think he charges other people more.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2023
I use PEEL N SEEL and so does Canaan.
Have has no problems with it at all. Has not even begun to peel for me in the southern heat. Just apply it right and you will be happy
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5322
I've used it with no problems.. make sure you clean the surface with some alcohol and use a roller to apply it
i'd suggest doing two layers since it is pretty thin
Username: Hittin1
Lake Charles, La. United States
Post Number: 825
how much of an improvment does the P&S make when applying it under the headliner? Can it be used to completely (or close to it) seal off the door panels? Tailgate?
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6548
I have 3 layers of it on my roof.
It worked wonders.
Back when I was doing 150-151 w/ no deadening, my roof was going crazy. It was horrible.
Now, w/ 3 layers and my truck doing 154's...the rattle is less back then.
Make sure you clean the surface well and you will be just fine.
Some types of that roofing-seal may smell a little at first, but w/ all the seal in my truck I get no smell. Even in 100deg heat w/ a dark blue truck, its fine.
One draw back though...on hot days my note drops 1-3hz.
I'm louder at night and at indoor shows. (hint hint)
