Bigger wire??
Username: Dubmc23
Rapid City, SD USA
Post Number: 264
the fed ex man dropped of my 12" kicker cvx's today and i hooked them up to my kx1200.1 but when i turn it up the amp will cut out and words sound all choppy...does this mean that i will need to upgrade from 4 awg to 0 awg wire??
Username: Loudon
Post Number: 2555
i would but i will look into upgrading alot of different aspects first ..
check ur connections .. make sure the ground is secure
secondly, make sure you have proper power running to the amplifier ...
what type of electrical system are you running? if its stock .. look into upgrading ur cars electrical system ...
double check everything and let us know what you find ... well help you to upgrade everything
Username: Dubmc23
Rapid City, SD USA
Post Number: 265
yea its a stock sysem...and ground is secure...what all do i need to upgrade in electrical system...battery and alternator?
